DIAdem Idea Exchange
About DIAdem Idea Exchange
Do you have a feature idea for how to improve NI DIAdem? Submit and vote on ideas now!
  1. Browse by label or search in the DIAdem Idea Exchange to see if your idea has previously been submitted. If your idea exists sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea. Be sure to submit a separate post for each idea. Note: the DIAdem Idea Exchange is not the appropriate forum to submit technical support questions.
  5. Give kudos to other ideas that you would like to see implemented!
The DIAdem R&D team is committed to reviewing every idea submitted via the DIAdem Idea Exchange. However, we cannot guarantee the implementation of any DIAdem Idea Exchange submission until further documented.
Top Kudoed Authors
User Kudos Count
1
To be able to create a REPORT with different page (sheet) sizes
Being able to create a report with different page sizes
At the worksheet parameters you can choose to use local page format, but you can only select the orientation (portrait or landscape). I Propose to add page size property when you select to use local page format, being able to indicate Height, Width or ratio.
5 Comments
Trusted Enthusiast
Trusted Enthusiast
Hi mdelsol,
Do you really want to change the page size from REPORT sheet to REPORT sheet?  Typically people want either A4 of 8.5x11 for ALL the sheets in a given REPORT.  There is a separate dialog ("REPORT>>Settings>>Layout Setup>>Parameters") for the whole TDR file that enables you to choose a page size.  If you do want to change the page size from sheet to sheet, could you please describe the scenario under which this would be desirable?
Brad Turpin
DIAdem Product Support Engineer
Member mdelsol
Hi Brad,
Your assumption is probably correct if you want to perform the complete report using only DIAdem, but isn't our case, we use Word and Excel templates for different reasons. We have specific TDR templates to plot the results of the different analysis performed and to create an EMF image of each sheet then the image is inserted in the report. In this case the image size is related to the page size, then for us would be very convenient to be able to have different sheet sizes. All of this process is automatized using DIAdem.
Marc.
Member nimic
Hello
And as to my experience, EMF and WMF never fare very well in rescaling. typcally, font sizes are a big jumble. So making the size fit in the source yould be helpful.
Michael
Member dietfons
Status changed to: Declined
Dear mdelsol, sorry for declining this suggestion because of following reasons:
(1) On the monitor, you wouldn't have an advantage because of sheet-autoscaling to a maximum display size
(2) It could only be relevant on printers: Here you couldn't choose different paper sizes for an automized print job. You have to handle different print jobs, so hopefully you could also use different REPORT layouts for different sizes.
Member mdelsol
When you create a report most of the times is to print it and if you let the user to choose the page orientation for a specific page (special page) doesn't make sense to limit it to the same page size.
To save DIAdem graphs as images you have to create them in the report and the sizes are related to the page size...
Unfortunately declining this idea you are limiting the user possibilities and doing DIAdem less user friendly.
Anyway thanks for considering and answering the idea.
