I checked the DIAdem hepl and saw that the time value converted in text only allows 4 digits for the fraction of a second.
But how can you display datetime in text for more precise values.
For example, if i acquire on a real time target, analog inputs data at 1MHz, all samples are more precisely time stamped than the best text value that you can display.
It would be very convenient to display time stamp like that : 06/19/2013 15:37:50.12345678
instead of that : 06/19/2013 15:37:50.0005
Thanks !
Best Regards
CFOE
Hi cfoe, et al.,
DIAdem 2018 finally ships with the option to expand the precision of time channels to better than 1 msec (in our century). For backwards compatibility we left that option turned off by default. Go into the DIAdem settings dialog, then under "General" check the "High resolution for absolute time values" checkbox. If you then save your *.DDD file, this setting change will persist each time thereafter that you restart DIAdem.
Brad Turpin
DIAdem Product Support Engineer
