It is very easy to delay the start of a video in order to offset the beginning of a video to a data set. However it is more difficult to offset data in order to synchronise with another section of a video.
For instance - you may have a 12 second video with 6 seconds worth of data. If this data relates to 6-12 s of the video, you need to change the x-axis of the 2D-axis area to mirror 6-12 s.
I would propose a "Video Offset" property. This suggestion is similar to Time Shift Data Feature.
Hi Pete, please do the following steps to solve your use case:
(1) Video-Display dialog: Set Start time to a negative value, e. g. -10
(2) Please select the video area to set the focus onto it
(3) Click the "Go to start" button in the VIEW command bar
(4) Start with "Play" button
Please be aware that to set the focus to the video area is important for this use case. Otherwise you must zoom/move the 2D-Curve in a synchronized 2D Axis System to the right side to set the cursor to negative X-values so that the video can start before the data-synchronisation begins.
