DIAdem Idea Exchange
About DIAdem Idea Exchange
Do you have a feature idea for how to improve NI DIAdem? Submit and vote on ideas now!
  1. Browse by label or search in the DIAdem Idea Exchange to see if your idea has previously been submitted. If your idea exists sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea. Be sure to submit a separate post for each idea. Note: the DIAdem Idea Exchange is not the appropriate forum to submit technical support questions.
  5. Give kudos to other ideas that you would like to see implemented!
The DIAdem R&D team is committed to reviewing every idea submitted via the DIAdem Idea Exchange. However, we cannot guarantee the implementation of any DIAdem Idea Exchange submission until further documented.
Top Kudoed Authors
User Kudos Count
1
1
Supporting Spaces In Property Names
I have a project where we have a fixed TDMS "schema" (layout and properties) which are used by a data server to import the files.
I have found that opening and saving the files in DIAdem causes any spaces to be replaced with underscores. From the perspective of my data server the file is now corrupt.
I would like DIAdem to support these spaces as they are clearly supported by the TDMS specification.
James Mc
CLA and cRIO Fanatic
My writings on LabVIEW Development are at devs.wiresmithtech.com
1 Comment
Proven Zealot
This is a limitation of DIAdem as far as I am aware.  There have been several discussions about it.  I'd rather DIAdem, and the DataFinder Toolkit not modify my file either, but it seems this is a known issue that NI doesn't appear to be interested in changing.
http://forums.ni.com/t5/DIAdem/Spaces-In-Property-Names/td-p/2831180
Unofficial Forum Rules and Guidelines - Hooovahh - LabVIEW Overlord
Interesting in learning all you can about automotive CAN bus communicatin? Checkout my 9 part CAN Blog series.
