DIAdem Idea Exchange
About DIAdem Idea Exchange
Do you have a feature idea for how to improve NI DIAdem? Submit and vote on ideas now!
  1. Browse by label or search in the DIAdem Idea Exchange to see if your idea has previously been submitted. If your idea exists sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea. Be sure to submit a separate post for each idea. Note: the DIAdem Idea Exchange is not the appropriate forum to submit technical support questions.
  5. Give kudos to other ideas that you would like to see implemented!
The DIAdem R&D team is committed to reviewing every idea submitted via the DIAdem Idea Exchange. However, we cannot guarantee the implementation of any DIAdem Idea Exchange submission until further documented.
Top Kudoed Authors
User Kudos Count
1
Split-screen in DIAdem SCRIPT
When working in DIAdem SCRIPT, it is often necessary to work on more than one file at once. The way this is implemented at the moment is with tabs:
However, it can be quite tedious to switch back and forth between 2 scripts for things like copy/pasting, comparing code or simply editing code on 2 files concurrently.
My suggestion would be for a SCRIPT editor with split screen functionality, roughly like this:
With many users working with widescreens today, this would better make use of screen real-estate.
5 Comments
louval
N/A
Obviously coding without it is a pain. Louval
dietfons
N/A
Newton2k1
N/A
Hi jtagg82,
My personal opinion is, that your idea is excellent. However, there is already some text editors which are able to do what you requested. You may just use one of those with split screen functionality to try-out how you would profit from this function.
We use for another application the program UltraEdit, which allows also to connect with a help file. UE with all of its features costs some tens of bucks but Notepad++ might do as well what you want.
A collegue of mine uses NP++ for DIAdem programming and can collapse sections, by means of NP++'s language detection.
Lukas.Doubek
N/A
I vote this feature, as well with possibility of moving tabs of opened scripts.
RavensFan
N/A
If you want to vote for this feature, then be sure to click the Kudo button to the upper left.  Just saying "I vote" is not the same as actually voting for it.
