DIAdem Idea Exchange
About DIAdem Idea Exchange
Do you have a feature idea for how to improve NI DIAdem? Submit and vote on ideas now!
  1. Browse by label or search in the DIAdem Idea Exchange to see if your idea has previously been submitted. If your idea exists sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea. Be sure to submit a separate post for each idea. Note: the DIAdem Idea Exchange is not the appropriate forum to submit technical support questions.
  5. Give kudos to other ideas that you would like to see implemented!
The DIAdem R&D team is committed to reviewing every idea submitted via the DIAdem Idea Exchange. However, we cannot guarantee the implementation of any DIAdem Idea Exchange submission until further documented.
Top Kudoed Authors
User Kudos Count
1
1
SUD Editing Improvements.
Hey All,
I've been working with a lot of SUDs lately and I've thought of a few things that could help make their editing process easier. First off, it would be nice to be able to view the SUD script and the display at the same time. I think a split screen view of the display and the script would help streamline SUD creation. It's a bit cumbersome to have to switch back and forth between the two.
The other idea is to make layer  editing easier. Having faster way to switch which layer you are editing and a checkbox to select which one is the true default are a few ideas. I've run into a couple of occasions where I am editing one layer that is dependent on the first and have to switch back to the primary layer to test the SUD before switching again to continue editing. Additionaly, it would be  easier to edit layers if we could more quickly switch layers, through use of something like the tab system used to switch which sheet you are looking at in the report.
Let me know what you think,
Artemis
1 Comment
Trusted Enthusiast
