DIAdem Idea Exchange
About DIAdem Idea Exchange
Do you have a feature idea for how to improve NI DIAdem? Submit and vote on ideas now!
  1. Browse by label or search in the DIAdem Idea Exchange to see if your idea has previously been submitted. If your idea exists sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea. Be sure to submit a separate post for each idea. Note: the DIAdem Idea Exchange is not the appropriate forum to submit technical support questions.
  5. Give kudos to other ideas that you would like to see implemented!
The DIAdem R&D team is committed to reviewing every idea submitted via the DIAdem Idea Exchange. However, we cannot guarantee the implementation of any DIAdem Idea Exchange submission until further documented.
Top Kudoed Authors
User Kudos Count
4
New channel type "calculation channel" in Data Portal
Rather than a channel that has a "fixed" value (numeric or string), this new "calculation channel" type would be a function of other channels.  Currently, if Channel3 = Channel1 + Channel2, and then I change the values for either Channel1 or Channel2, I have to re-execute the calculation
ChnCalculate("Ch(""Channel3"") = Ch(""Channel1"") + Ch(""Channel2"")")
Now, if there was a "calculation channel" where I could define Channel 3 as "Channel1 + Channel2", I wouldn't need to perform this re-execution!
Another way to explain is to have a channel that works like Excel calculation cells.  The cell calculation stays the same, and when the input cells change, the result cell is automatically updated.
I'm not sure if I explained this well, please ask for clarification if necessary.
11 Comments
Trusted Enthusiast
Trusted Enthusiast
Hi Julia,
I've wanted this exact functionality for a long time.  Thanks for bolstering my case with R&D.
Brad Turpin
DIAdem Product Support Engineer
Nnational Instruments
Member MortI80
Very nice idea, this would be really helpful...
Member MarredCheese
This is a must.  Since most of your users are probably coming from an Excel background, they expect this capability to be there.  When I started using DIAdem, I was pretty surprised that all calculations didn't work this way.  I feel that without this feature, I have to fall back on scripting a lot more.
Member MarredCheese
<deleted comment since I put it in the wrong thread by mistake>
Member 唐老鸭
Member 唐老鸭
抓 捕 徐 才 厚
Member dietfons
Member sg000
I think this would provide a fantastic improvement in useability. You could pre-create a Group of Channels that are essentially calculations. Then when you load your data set, you load in the new group and BAM, all your pre-defined calculations are completed, no scripting required. Like Marredcheese expressed, most are coming from Excel background expecting auto calculations. Frankly, more people CANNOT do scripting than can, and it'll severely limit your customer base over time. I love programming, but the high requirement of scripting made me hesitate implementing this software for our company.
Member jack__
sg000 hit the nail on the head. SCRIPT is nice but sometimes it's a little much to learn to just get someone on track to do some simple analysis. Being able to set up a DIAdem workspace as a rough analog for an Excel workspace would really help some non-power-users get acquainted with DIAdem for their own uses.
Active Participant AndreasH_Ha
The requirements you described (as far as I understand them) are covered by the "CalculationManager" in DIAdem ANALYSIS. Calculation-Manager allows you to create the formulas you described (even nicer) and you can execute a whole set of calculations in one step with no programming required. What you would do is load the data, execute the formulas and you will have the new channels you asked for .
