Thank you for your request. We understand your suggestion but given the age of this entry and the fact that just a few sponsors are supporting it, we have decided to decline this suggestion and prefer to develop more frequently requested features instead. We hope you understand this.
Greetings
Walter
The default type for a 2D Axis view display is line, but for all our signals we need stair curve. So I have to manually go to display settings and set the type to stair curve for every channel. If there are many channels that is very tedious. It would be nice to have a global setting that can be set for all view displays.
While almost everything could be set in dialogs or ini-files, sometimes it may only take a few lines of code to get the same result. The attached example uses the "for each ... in ...next" construct to change all "lines" to "step curves".
Hello jakidd,
Greetings
Walter
