DIAdem Idea Exchange
About DIAdem Idea Exchange
Do you have a feature idea for how to improve NI DIAdem? Submit and vote on ideas now!
  1. Browse by label or search in the DIAdem Idea Exchange to see if your idea has previously been submitted. If your idea exists sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea. Be sure to submit a separate post for each idea. Note: the DIAdem Idea Exchange is not the appropriate forum to submit technical support questions.
  5. Give kudos to other ideas that you would like to see implemented!
The DIAdem R&D team is committed to reviewing every idea submitted via the DIAdem Idea Exchange. However, we cannot guarantee the implementation of any DIAdem Idea Exchange submission until further documented.
Top Kudoed Authors
User Kudos Count
1
1
Multiple manual scales for multiple waveforms on one graph in VIEW panel.
Hello ALL,
there is only one manual scale to be set in a 2D graph in VIEW Panel. It would be a great idea if setting manual scales would allow you to set seperate scales for seperate plots on one graph.
Thanks, Piotr
Best regards, Piotr
Certified TestStand Architect
Certified LabVIEW Architect
2 Comments
Status changed to: In Development
Status changed to: Completed
Hello Piotr,
The feature you requested has been realized in DIAdem 2014. Follow these steps to make use of it:
  • In a VIEW 2D chart in DIAdem 2014 choose "n Y-Axes [Linear]" for the Y-Axis type to display an individual axis for each curve.
  • Open the "Display..." dialog to access the parameters of the chart
  • In the dialog check the scaling item "Curve related" to display the additional "Scaling" column in the curve list
  • To define an individual scaling for a curve choose "Edit..." from its scaling drop down box. This opens a new dialog which allows you to define a number of named manual scalings. Press OK to confirm your definitions.
  • Each of these named scalings can now be selected for each of the curves in your chart. Selecting the same scaling for multiple curves results in them sharing the same y-axis
Marcus
