Since DIAdem 2014 there is the AddElementList method (see the online help for that topic).
set oList = data.CreateElementList
oList.Add(xxx) ' add one Data-Element to the collection
oList.AddElementList(yyy) ' add one Data-Element-List to the collection
Starting with DIAdem 2015 the method has an additional optional parameter selecting between different ways to merge the lists.
Marcus
Hi
I have create an Element List filtering some channels of a group
Dim mSyncLst, iGrp Set iGrp = Data.Root.ActiveChannelGroup Set mSyncLst = Data.GetChannels(iGrp.Name & "/ABC*") 'List With Several Channels
I would like to add to the mSyncLst the channels containing DEF. e.g. Data.GetChannels(iGrp.Name & "/DEF*"), which also contains several channels. Using the method Add mSyncLst, only allows to append one channel each time.
Marcus
