DIAdem Idea Exchange
About DIAdem Idea Exchange
Do you have a feature idea for how to improve NI DIAdem? Submit and vote on ideas now!
  1. Browse by label or search in the DIAdem Idea Exchange to see if your idea has previously been submitted. If your idea exists sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea. Be sure to submit a separate post for each idea. Note: the DIAdem Idea Exchange is not the appropriate forum to submit technical support questions.
  5. Give kudos to other ideas that you would like to see implemented!
The DIAdem R&D team is committed to reviewing every idea submitted via the DIAdem Idea Exchange. However, we cannot guarantee the implementation of any DIAdem Idea Exchange submission until further documented.
Top Kudoed Authors
User Kudos Count
1
DIAdem VIEW zoom improvements
I'd like to propose a few improvements to the zoom functionality in DIAdem VIEW that are sorely missing usability-wise:
  1. Vertical band zoom: This would allow one to zoom in on a specific part of the y axis without touching the x axis. We have the horizontal, why not vertical?
  2. Sticky zoom button: When I want to zoom in to a specific part of a graph in successive steps, I have to click on the zoom button each time. It would be great to be able to click on it once to activate the zoom tool and to be able to zoom several times. (Not sure what the best mechanism is, but maybe a click with modifier key? Ctrl+click on zoom button keeps it active?)
  3. Zoom stack with undo: Following on from point 2, when I zoom in in successive steps, it would be nice to be able to go back to the previous zoom level. Right now I can only do a generic zoom out or cancel all zooming. It could simply be an extra button in the zoom palette that goes back up one level in the zoom stack (like an undo. It could even be integrated into a more generic undo functionality if it ever comes about.)
I think that for points 2 and 3 there are several ways this could be done. I think the focus should be on usability. The user needs to be able to navigate the data as quickly and as efficiently as possible and the current zoom implementation is clearly impractical for many users.
3 Comments
Brad_Turpin
N/A
Hi jtagg,
I like your suggestions.  For your 2) above, try right-click + drag, that will re-zoom based on whether you have band zoomed or frame zoomed last.
Brad Turpin
DIAdem Product Support Engineer
jtagg82
N/A
Hi Brad, Thanks for the info. I had tried a few things to see if I could repeatedly zoom, but hadn't thought of that. Maybe for point 2 just make the feature more discoverable? jtagg
dietfons
N/A
