DIAdem Idea Exchange
About DIAdem Idea Exchange
Do you have a feature idea for how to improve NI DIAdem? Submit and vote on ideas now!
  1. Browse by label or search in the DIAdem Idea Exchange to see if your idea has previously been submitted. If your idea exists sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea. Be sure to submit a separate post for each idea. Note: the DIAdem Idea Exchange is not the appropriate forum to submit technical support questions.
  5. Give kudos to other ideas that you would like to see implemented!
The DIAdem R&D team is committed to reviewing every idea submitted via the DIAdem Idea Exchange. However, we cannot guarantee the implementation of any DIAdem Idea Exchange submission until further documented.
Top Kudoed Authors
User Kudos Count
1
1
Curve and AxisDefinition config window in DIAdem VIEW
In VIEW tab, when working with 2D-graphs some times it is useful to change the line width, the background color, the axis color, the line style... as in the REPORTER tab because for analyzing and studying the data before having the final data to report, the VIEW tab offers much more comfort. The Curve and Axis Definition in REPORT can replace the current 2D Axis System Display window:
6 Comments
This is really crucial! Thank you, Best regards, Hugo
Please consider colorblind people as well (high contrast between colors)
Status changed to: Under Consideration
Yes, I like this idea, but can you also add the capability to play a video behind a graph. Like making the video transparent.
All played within the same area. Not an area next to it, like you can at the moment. Obviously it would be good to have all the data synched together.
Stagsden
This would be a great future to add.  I often look at experimental data in view and would rather look at the data as point to point, but there is always a line connecting my points.
Hi noscho,
Displaying the data as points without connecting line can be achieved by switching on markers with a color of your choice and at the same time setting the line color to none.
Marcus
