When dragging and dropping a channel into a View or Report table from the Data Portal, no matter where you release the channel, it's always appended to the end. This can be frustrating if you have a large number of channels in the table, forcing you to rearrange the table after each channel is added.
I would like to propose the ability to drop channels in-between columns of the table, OR append channels on the end.
I would think that the area you drag the channel into would decide where it inserts:
Between 2 channel headers (anywhere in the "Selected Channels" section or above) = Insert
Anywhere on the "Channel Contents" section, row numbers, or blank area without channels = Append to end
Thanks!
-Josh
