This feature was just released with DIAdem 2012. You could use the format instruction 'str' to do the following:
Use '$' to display numeric values in hexadecimal format. If more characters follow after the first $ character, DIAdem uses this character as the prefix for the result, for example:
Call MsgBoxDisp(str(1234,"$0x")) ' => 0x04D2
If further $ characters follow after the prefix, these characters indicate the number of places. DIAdem interprets all characters behind the last $ character as postfix, for example:
Call MsgBoxDisp(str(1234,"$ $$$$$$$$hex")) ' => 000004D2hex
If no further character follows after the first $ character, DIAdem shows the number to be formatted as a hexadecimal value and uses the $ character before the numbers as ID for the hexadecimal display: Call MsgBoxDisp(str(1234,"$")) ' => $04D2
The DIAdem prefix for hex data is $ and as I am aware you must use this. Most programs use the prefix 0x. There should be an option to chose one, the other or none.
James Mc ======== CLA and cRIO Fanatic My writings on LabVIEW Development are at devs.wiresmithtech.com
