NI Home
Cart Cart | Help
You are here:
Announcements
Bitte verfassen Sie Forums-Beiträge in englischer Sprache. Damit ermöglichen Sie internationalen Benutzern, sich an den Diskussionen zu beteiligen. Falls der Aufwand nicht zu groß ist, werden deutsche Beiträge ins Englische übersetzt.
jrk3z
Better Management of Report Pages
Status: New
by Member jrk3z on ‎04-06-2012 09:52 AM
Right now, you can only delete one page at a time (using delete or the "manage...") feature.
Why cant I just select multiple pages and "delete all".  Or in the "manage..." feature, why cant I select more than one at a time (otherwise what is the little check box for?) and delete all?
Would be very helpful to add these features
Comments
by Active Participant AndreasH_Ha on ‎04-06-2012 11:25 AM
assuming that you use DIAdem 2011, selecting multiple pages and then deleting them should work.
by Member jrk3z on ‎04-06-2012 11:55 AM
I am using Diadem 2011
Diadem: 11.3.0f4563 TDM
USI: 1.9.0f4551
DataFinder: 3.0.0f4556
and it is not working.  I am using the CTRL to select multiple sheets, and then right clicking and clicking delete...only one sheet deletes...
what am I doing wrong?
by Active Participant DRock on ‎04-09-2012 09:42 AM
Hi jrk3z -
The checkbox in the "Manage" dialog switches which page is displayed.
It seems that currently using CTRL to select multiple pages in the "Manage" dialog doesn't work - we'll file this feedback to R&D.
However, in the meantime, using the SHIFT key to select multiple pages in the "Manage" dialog works just fine - simply SHIFT-click to select multiple pages and then select the "Delete Worksheet" button.  Please note that this follows the typical Windows convention where SHIFT-click will select only consecutive items - I understand that this is where CTRL-click would be a valuable use case.
by Active Participant AndreasH_Ha on ‎04-09-2012 09:53 AM
SHIFT is used to select one consecutive block (one or more items), which is what currently supported. We'll discuss support for CTRL and with that support for deleting several blocks as new/improved feature
by Member jrk3z on ‎04-09-2012 11:05 AM
Thanks much.
I also think that it would be useful to be able to select more than one sheet without using the Manage function.  For instance, why cant I just use CTRL or SHIFT to select more than one tab from the REport View and delete from there?
About DIAdem Idea Exchange
Do you have a feature idea for how to improve NI DIAdem? Submit and vote on ideas now!
  1. Browse by label or search in the DIAdem Idea Exchange to see if your idea has previously been submitted. If your idea exists sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea. Be sure to submit a separate post for each idea. Note: the DIAdem Idea Exchange is not the appropriate forum to submit technical support questions.
  5. Give kudos to other ideas that you would like to see implemented!
The DIAdem R&D team is committed to reviewing every idea submitted via the DIAdem Idea Exchange. However, we cannot guarantee the implementation of any DIAdem Idea Exchange submission until further documented.
Top Kudoed Authors
User Kudos Count
3
1
1
1
1
