DIAdem Idea Exchange
About DIAdem Idea Exchange
Do you have a feature idea for how to improve NI DIAdem? Submit and vote on ideas now!
  1. Browse by label or search in the DIAdem Idea Exchange to see if your idea has previously been submitted. If your idea exists sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea. Be sure to submit a separate post for each idea. Note: the DIAdem Idea Exchange is not the appropriate forum to submit technical support questions.
  5. Give kudos to other ideas that you would like to see implemented!
The DIAdem R&D team is committed to reviewing every idea submitted via the DIAdem Idea Exchange. However, we cannot guarantee the implementation of any DIAdem Idea Exchange submission until further documented.
Top Kudoed Authors
User Kudos Count
1
1
Automatic indentation
Hello everybody,
My suggestion concern the SCRIPT tab. I think that it is necessary to implement a real automatic indentation function as you can find in most of Integrated Development Environment.
Indeed, when you write a VBS code, you have to structure your code manually while DIAdem could structure it automatically.
For instance, after an "if" and until "end if" DIAdem could insert a tabulation.
Thomas77,
1 Comment
