Hi all,
sometimes it can be an advantage for data manipulation to have the possibility to access to an index channel (a channel just containing the values from 1 to n) generated out of channel with length n.
Such a channel would be helpful when using event search function which have to be performed on a certain number of values o in a certain block of data in a channel.
This function could be integrated in the current function "Generate Numeric Channel".
Best regards
Hello
Thank you for your request. R&D has read this suggestion and it will be included in feature planning discussions for future DIAdem versions.
Greetings
Walter
