DIAdem Idea Exchange
JuliaDawkins
Allow hyperlinks in REPORT layouts
Status: Under Consideration
Hello
Thank you for your request. R&D has read this suggestion and it will be included in feature planning discussions for future DIAdem versions.
Greetings
Walter
I would like active hyperlinks to be allowed in REPORT layouts.  For example: http://www.ni.com/diadem/.  Clicking on this link (in the REPORT layout) would result in the user's default internet browser to open to the link.
6 Comments
JuliaDawkins
Ok, I can use a webpage in a SUD dialog in VIEW for now...!
AndreasH_Ha
NI Employee (retired)
Hello Julia,
Can you please give an example for the use case you have in mind ?
Would you typically link to a webpage or would this be a link to a local document ? Or both ?
Andreas
JuliaDawkins
Both would be great - I could see cases where we would link to a website (http://www.ni.com), a UNC path (\\server\folder\filename.txt) or local file path (c:\Temp\Document.txt).
SEgeler
Hi!
Yesterday I talked to a customer who wanted to use a kind of Web Report with links to server files. The Idea behind that is to keep downloadable reports small - "if you need the additional information, you can click on these links"
Have a nice day,
Stefan
dietfons
Walter_Rick
Status changed to: Under Consideration
Hello
Greetings
Walter
