NI Home
Cart Cart | Help
You are here:
Reply
Member
cwilliams0336
use a Switch or similar in DasyLab to initiate the worksheet to start averaging data in a particular channel
Can you tell me if it's possible to use a Switch or similar in DasyLab to initiate the worksheet to start averaging data in a particular channel for a set time, say 60 seconds, then have the averaged result sent to an Excel file. I have been playing with the DDE module and have been successful in having DasyLab send data to Excel.
I spending lots of time browsing the help files and modules but I could really use a little help.
Active Participant
CJ_Butler__DASYLab_Pro
Re: use a Switch or similar in DasyLab to initiate the worksheet to start averaging data in a particular channel
Sure.
I can make you an example -- but I need to know your sample rate and block size.
- cj
Member
cwilliams0336
The sampling rate is 0.2 and the block size is 1.
Active Participant
Do you have V12?
Here's a worksheet.
- cj
Member
cwilliams0336
Hi CJ,
Thanks for the worksheet. I only had 5 minutes at the end of the day today to take a quick glance. I'm not sure what it's supposed to do, maybe I'm too impatient. Should I click the one-shot switch then see averages of generator data listed once a minute. Can you provide a short explanation? I'm fairly new to DasyLab so I have to spend a lot of time reading help screens on modules especially ones I've never seen or used before like Relay, Siwtch and Combi Trigger.
Active Participant
How's this explanation?
- cj
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
