DASYLab
select a range of data
Hi everyone,
I would like to know how to do to select a range of data (for example on a force/time graph during a jump landing (parable), from a certain value to another) to register it on a special file? I tried the module "separate" or "cut out" but I don't think they will be useful when you don't know when will appear the specifical value you're looking for...
Is it also possible in Dasylab to know the director coefficient of this type of curve (quite linear...)?
Thanks!
(6,237 Views)
Please look at the Trigger module group. Use the trigger to select the range and the Relay to remove the data until the trigger is detected.
There are at least two trigger examples in the DASYLab Help->Examples. Please review them for hints on how to configure the triggers.
I'm not sure I understand your second question... are you looking for the Regression module?
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(6,226 Views)
Can you give us some graphs of what you're trying to do?
I also would encourage you to look into DASYLab classes in your area
Tom Rizzo
InSyS Corp.
www.insyscorp.com
Your DASYLab integrator
(6,224 Views)
here you are the type of curve I found. I need to find the coefficient director of the line between A and B (formula : (Yb-Ya)/(Xb-Xa). I guess that first, I have to use the regression module between the 2 points and then... How can I do? It's easy on Excel but I'll try to use only dasylab... 🙂
Yes, I'll suscribe to dasylab classes if they make vouchers 😉
(6,213 Views)
Accepted by topic author M.Charbonneau
Perhaps...
Select the values in a block (y values) at given positions (y values).
Calculate the differences, and calculate the quotient.
M.Sc. Holger Wons | measX GmbH&Co. KG, Mönchengladbach, Germany | DASYLab, DIAdem, LabView --- Support, Projects, Training | Platinum NI Alliance Partner | www.measx.com
(6,184 Views)
