NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
John237
Accepted Solution
pre-trigger
I am trying to eliminate the "lag" data before an arbitrary trigger event (only on the graph, but if the file need to be truncated so be it!) and am having no luck.  Please see the graph below for reference.
Any help will be appreciated.
Active Participant
CJ_Butler__DASYLab_Pro
Re: pre-trigger
Use a Combi Trigger module with the defined pre and post trigger settings, and then use it to control a Relay module where you route the rest of the data through. The Relay will release data while the trigger is active (high), and not while it's off (low).
You can write the data before the relay to write all of the data, or after the relay to only write the desired triggered area.
- cj
Member
John237
Re: pre-trigger
Seems so simple now!!!!
You are the best!
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
