Ver 11 is a litle old and you should try with version 13.
In version 13 you need to find out if it is the register 300000 or 400000 and then you select which register and which address.
All this is performed with the ModBus module.
I am assuming you have the proper interface card and you selected the proper COM address in DASYLab.
If you post the manual with all the registry information, maybe I can look into a little better.
In any case I suggest to upgrade to V13
Tom Rizzo
InSyS Corp.
www.insyscorp.com
Your DASYLab integrator
