Yes, You can. Display instruments such as the Chart Recorder, bar graph and digital meter all can display data with differing time stamps.
Each data generator, whether it's an Analog Input or a RS232 input has to time stamp the data. If you need to, you can force the RS232 to pace to a different time base, and use that setting to synchronize with a faster Analog Input. It will repeat the last data point until a new data point is received.
Measurement Computing (MCC) has free technical support. Visit
www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
