05-14-2013 10:20 AM
I would like to take 2 channels from a data trigger and have them hold a solidstate relay closed until the trigger event.
Any idea's what module could I use to perform this task.? Thanks. Kent
05-14-2013 12:24 PM
Kent,
I need a bit more explanation. Is the data trigger the DASYLab Data Trigger module or is it a Digital Input?
...until the trigger event.... what trigger event?
I would look at the Latch module or the FlipFlop module.
05-14-2013 12:33 PM
Sorry ,It's a dasylab data trigger module setup to trigger within the limits I have set.
The data trigger works on my status indicators, green for good, red for bad . When the staus is
green I require a NC solidstate control relay and when it goes red I require that relay to open.
05-14-2013 12:44 PM
I tried using a digital output but I believe because I'm using the analog input to get my required speed this is not possible. Is there a way of programming and
wiring an analog output to control this solidstate relay.
05-14-2013 12:59 PM
Which hardware are you using?
05-14-2013 01:06 PM
Hi Tom
USB-1208FS
Analog subsystem
5000Hz / 100 samples/block
Works great at my speed requirement. CJ and Jeff helped me out of a bind when they suggested going to analog instead of the slower digital sub system.
But I still require a way to get a signal out to my machines solid state relay for a stop command when the data goes out of range and status goes red.
05-14-2013 01:45 PM
To my understanding, I also have a 1208FS in my stock, you should be able to connect it with a digital output very easyly.
The manual would explain it how to do it wire it.
Obviusly, do not expect a super fast reaction but it should be good enough.
05-14-2013 01:55 PM
I have tried to add a digital output but it seems to slow down the analog input also.
I will test further this way to see what's really going on. The digital output speed is
not as big a factor in this experiment. Thanks Kent.
05-14-2013 02:01 PM
That is strange, when you're done with the design, post it and maybe we can quickly test it
05-14-2013 02:15 PM
It doesn't appear that It will let me use a digital output with out changing my scan rate.
