10-20-2014 07:34 AM
Good Morning! I'm trying to open an ASCII file, which was collected through MegaWin software. However, when trying to open I get the following message: "The Set block size is larger than the number of lines in the ASCII file". I need to run the file in order to pass a filter on data from electromyography. If anyone can help me I will be very grateful!
10-20-2014 09:47 AM
The Read Data module defaults to using the Driver timebase. If you don't have enough samples to fill a block, then you encounter this error message.
Click on the Ascii options setting to change the sample rate/block size to one that reflects your data. You need a block size of more than 1 to use the digital filters.
10-21-2014 06:49 AM
Ok! Thanks for your help and attention!
