DASYLab
Using a data output file as an input file for test development
I have an output file from a system that I would like to use to simulate the device being attached to the computer.  Using the read module I can input the entire file into the charting module, but it reads the entire file.  Is there a way setup the input to read one line approx. once per second and chart it (i.e.. A 3600 line file would take approx. 1 hour to read and chart)?
Thanks in advance.
(5,765 Views)
I would like to verify that you are using DASYLab for this application. If you are, our developers do monitor this forum and will be responding when they return from the holidays. I hope you have a great day!
Jason D
(5,742 Views)
Set up the Read module to only read once per second or minute....
If you're reading a DDF file, it will always read back a full block of data, so you want to have stored the data at one sample/block. One way to do that is to read it back and write is out as ASCII, so that DASYLab loses the block size context.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(5,737 Views)
