DASYLab
Send different commands to RS232 during measurement
Martin, you should have posted this as a new question.
Without knowing the version of DASYLab, the level (Full, Basic, Lite, Pro) or the device that you are communicating with, we can only suggest some general things.
Create a RS232 Output module and configure it for the correct communications port. If you just need to send a command, configure the module to send commands, not data. Then enter the command in the command box. Use \r to send a <CR> and \n to send a <LF>.
To use a data event or time event to trigger the RS232 module to send the command, you need to activate the setting to use an input. This input will look for 0 or 5, and 5 (TTL High) will send the command. You can also use an Action module to send the command  without an input on the RS232 output module .
You can use a Trigger or a Comparator module to determine when to send the command, or, any other technique that will provide a TTL high for the RS232 module.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
Message 11 of 12
(2,650 Views)
Dear Cj
Ok, I'll post it as a new question tomorrow as I need to see the machine. I'll provide the complete information later.
Thx
Martin Wijaya
Message 12 of 12
(2,647 Views)
