12-06-2007 08:31 AM
12-12-2007 04:50 AM
Hi Bas,
Did you test the DAQmx outputchannel in MAX? Does it work?
For Dasylab questions, you can contact MeasX.
Bas
12-12-2007 05:03 AM
12-18-2007 07:18 AM
sorry but DASYLab 9.x NI-DAQmx Online help clearly say:
"... Set Output to ... at Stop of Experiment
When the measurement stops, you can set the outputs of the module to a specified value. Enter a value or the name of a global variable.
Click Task for job to select a NI-DAQmx task of the Measurement & Automation Explorer (MAX) that DASYLab uses for the output.
Note DASYLab only supports the NI-DAQmx tasks that use the signal generation mode 1 Sample and the corresponding physical channel. |
MHa
12-19-2007 06:28 AM
12-19-2007 06:55 AM
