want to control over RS232Output Module (DasyLab7) a relayboard. Therefore i have to send the following string: 7Eh-20h-01h-06h-01h-04h-00h-00h-7Eh (Set) and 7Eh-20h-01h-06h-01h-04h-00h-01h-7Eh (Reset). The Serial Interface Setup is ok and i've enabled "Asynchronous Command" and disabled the "With Control Input", but every time i try sending the string via Output(Format) the board is not responding. I know for sure that the board is functioning ok, because i am using it with a software i wrote in Delphi. Thanks in advance for any help!
Giannis K.
