01-22-2015 12:06 AM
Hi
I try to control power supply model for this action i need to send command to the unit
first command is :ADR01; its the address of power supply number one.
then i need to send the command :OUT1; this command get the power supply on.
can you send me some shoot screen how to send this in rs232
thank you .
Eyal
01-22-2015 02:39 AM
Manual "5.5.1 Init control", p. 42, #3 says that you need to switch the device manually into remote mode using some button on the the device's front panel.
Place a RS232 input module into the worksheet.
Configure the interface settings.
Go to the RS232 monitor.
Enter :ADR1;:MDL?; then press enter (p.42). The device should answer with some information about its type, name, etc.
Is that working?
01-22-2015 02:56 AM
HI
I do it is not work.
01-22-2015 03:12 AM - edited 01-22-2015 03:20 AM
Oh, add \r and/or \n to the string
:ADR1;:MDL?;\r
or
:ADR1;:MDL?;\n
or
:ADR1;:MDL?;\r\n
EDIT:
Ok, the manual says that commands send to the device do not need \r, \n symbols.
Hmm, sometimes the manual uses a colon (p. 48 for example), sometimes a semicolon to present examples.
Perhaps you should try :ADR1::MDL?: with colons only.
