05-18-2007 08:37 PM
05-21-2007 10:24 AM
05-21-2007 06:28 PM
Dear Sir,
Greetings. Many thanks for such a prompt response. Here are some additional items for your consideration:
1. The NIDAQmx version that i have been working with is 8.5 and it came with the USB-6229.
2. I installed NIDAQmx on my development machine and all worked just fine.
3. I have tried, three times now, to install NIDAQmx on my home development machine and have had no luck with NIDAQms recognizing the hardware. In system, device manager, i do see USB6229 and when i check it i get a response that the device is working and is ready for use.
4. In NIDAQmx, i don't even see the NIDAQmx devices tab. All i see is the PXI.
5. The other strange thing is that when i installed NIDAQmx on my development machine, re-booted the sysem, then powered up the USB-6229, and selected to install the drivers automaticaly, i got a splash screen that asked if i want to configure the device. On my other system, i never get that splash screen.
6. The system i am having problems with is: Dual-Xeon workstation, 2GB RAM, running Win XP Pro SP2.
7. The only two things that i can think of that are different are:
a. The workstation was running a previous non-MX NIDAQ and supported a PCI-MIO-16XE-50 DAQ. However, that card was removed long time ago and the device was removed from "device manager". I also removed the legacy NIDAQ software.
b. The workstation is running Office 2007 Enterprise, Visio 2007, and Project 2007. I know that these apps should have nothing to do with NIDAQmx but i have found that there are some software apps which absolutely do NOT work with Office 2007 installed.
I would really like to get this issue resolved because i do most of my development work in my home office where my workstation has a lot more processing power than my work computer. Most of the work that i do with N.I. DAQ cards use DASYLab ver 9; with some of my applications, in VB6, are deployed to our international manufacturing plants to do electrical targeting.
Any help or guidance will be most appreciated. Should you find the time to call, my home office number is: 1.216.521.5769 and my work number is 1.440.899.6181.
Sincerely,
joe pavelchak (aka the ancient one - - much too old to keep doing this) 🙂
05-22-2007 07:31 PM
Hello.
I have a few tips that may help us resolve this problem sooner rather than later. First, I would recommend shutting down your PC and removing your 6229. Then reboot and uninstall/reinstall the DAQmx driver. Power down, plug in the USB device, and reboot. This will follow the recommended installation procedure of drivers before hardware and could resolve this issue. If you have already tried this, I would recommend acquiring other DAQ cards that you may have in your possession (or around the office). If we try these, and they work, then it points to an issue with that specific device. Also, do you have other devices (keyboard, mouse, etc) that are plugged into your USB bus? What happens if you remove all other USB devices from the computer and attempt to detect the 6229?
If you launch MAX, are you able to right click on "Devices and Interfaces">> "Create New" and then select "NI DAQmx Simulated Device"? After you select a specific DAQ device to simulate, are you able to see that under the NI-DAQmx devices tab?
Let me know and I will continue to assist you!
Brian F
05-22-2007 09:02 PM
05-24-2007 08:33 AM
03-09-2013 04:50 PM
I have the same problem. My mistake was that I installed a trial version of LabView 2012 with the device drivers on my Windows 7 32-bit OS. Once the trial version time was over I uninstalled everything. When I tried installing NIDAQmx 8.7.1f3, NIMAX would not see my USB-6229 for the life of me. It appears just fine under device manager. I have called NI numerous times and they can't figure out why or know how to go about troubleshooting. It would not even see my serial port devices. I had to separetly download and install NIVISA 5.2 and finally my serial port devices were listed in my NIMAX, but no USB-6229.
This also happened to me a few years back on a Windows XP Pro computer. If you mistakenly install the newer NIDAQ drivers and you ever have to back track or roll back NIDAQ drivers you are in for a HUGE surprise. I don't believe anything NI support told me that they have never seen that before etc. This has been an issue for years and they still haven't figured it out. They prefer you purchase newer products, rather than keep using the legacy products. Problem with that is I can't be speding 8K and 10K every two or three years just because they don't want to help and make the effort to figure out the issue.
