01-07-2011 10:14 AM
I need to install a usb-6009 in Dasylab, but Dasylab does not recogise daqmx-devices, or so it seems.
In MAX, I can see that I have traditional NI DAQ installed (7.4.2f3), but the usb devices are listed as daqmx devices.
Is there any way to trick Dasylab into seeing my device?
I usually work in Labview, but now I need to replicate a measurement from a colleague from Ethiopia and Dasylab is confusing in the beginning.
Would it be easier to use a pci card (we have pci 6220 available)?
max version4.3.0f0
daqmx 8.6.1f0
traditional NI daq 7.4.2f3
dasylab 8.00.00 from 2004, old, I know)
labview 8.2
Solved! Go to Solution.
01-07-2011 10:37 AM
If you can create an NI-DAQmx task with the device, DASYLab should see it.
There is a download for the NI-DAQmx driver for DASYLab 8.00.04 at www.dasylab.com
http://dasylab.com/content/driver.php?action=filelist&sid=33
We can only provide active support for current versions of DASYLab (V11 and V10), so, there isn't much help available.
01-10-2011 03:08 AM
Thanks!
Got it working.
05-16-2014 08:11 AM
I want to apologize in advance for incomplete technical competence
in the subject, because my amateur level of training.
I also want to apologize to experienced professionals
and especially Mr. CJ_Butler,
for my English machine translation.
I hope you will indulgent to the Russian citizen,
who is actively interested in operation
of the device NI USB-9006 program DASYLab.
In Russia, unfortunately, very few know
about object-oriented programming in the program DASYLab
(compared with a developed system of training LabVIEV).
Given the popularity of the brand as the NI USB- 6009 ,
I would like to understand in detail the stages of installation,
work in the program DASYLab. ( I use DASYLab 11 , in Windows XP)
My first question is as follows :
why I can not directly see and work with the NI USB- 6009 program DASYLab,
as it comes with a sound card or other devices e.g. , Measurement Computing?
When you open the tab «Hardware Setup» error appears: «No hardware driver loaded»?
Can we do without NI MAX ( task creation and other unnecessary actions (!),
and produce all presets in the program DASYLab (Hardware Settings)?
Indeed, in the program directory has the files as : nddi.dll, niezio.dll?
Why they can not determine the direct control of NI USB- 6009 in DASYLab?
2) Is there a " prime-driver » DASYLab for NI USB- 6009 in DASYLab 11 ? ? ?
Or how else can modify DASYLab driver (DASYLab NI-DAQmx (?)) for NI USB- 6009 ?
http://dasylab.com/content/driver.php?action=filelist&sid=33 (?)
http://dasylab.com/content/driver.php?action=filelist&sid=575 (?)
Thank You in advance for the opinions expressed.
Igor Viktorovich, from Russia
05-19-2014 08:30 AM - edited 05-19-2014 08:30 AM
Hello usserrostov,
Since your question is not related to the previous question in this post I think it would be best to post a New Message in this Forum Category:
http://forums.ni.com/t5/DASYLab/bd-p/50
