02-14-2008 01:31 PM
02-14-2008 02:27 PM
02-15-2008 07:43 AM
Thanks, I played around with the graphs. I
misunderstood the help file comment on the chart recorder. I took it to
mean 100Hz was the max sample rate.
The chart recorder works well. Although I can't get it to display the function
bar and menu in the layout like it does in the worksheet. Is there a trick to getting those to display?
In regard to the Y/t chart, I think you meant to say that it updates one block
at a time, not that it displays one block at a time.
It is not obvious or intuitive, in my opinion, how to make this graph display
longer blocks. The functionality is in the X scaling and is referred to
as width. Where the chart refers to it as display time.
Dave
02-18-2008 09:01 AM - edited 02-18-2008 09:02 AM
Joe Friedchicken
NI Configuration Based Software Get with your fellow OS users
[ Linux ] [ macOS ]Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
02-18-2008 09:04 AM
Thanks Joe,
I have tried that but the display doesn't change when I select the menu to display. Almost like it's displaying off screen or in an area where it is covered up.
Any other suggestions?
Dave
Original Message.......
Hi Dave,
If you right-click in the plot area, you'll get a pop-up menu that will allow you to display the menu and function bar.
Joe
02-19-2008 05:25 PM
Joe Friedchicken
02-20-2008 06:26 AM
