07-03-2013 07:08 AM
I would like to use NI USB-6341 with DasyLab 12.0 but I don't find any document related to that. Is it possible ? How to install the NI USB-6341 driver for DasyLab ? Thank you.
07-03-2013 07:19 AM
Any NI products works with DASYLab trough the MAX in DAQmx.
You will need to create a task in MAX, and then syncronize it in DAYSYLab.
So, if you can create a task with the USB-6341, you should be able to use it in DAYLab.
Make sure that you have installed the DAQmx driver with the DASYLab configurator
08-12-2014 09:21 AM
Hello all !
I accidently try to plug the Ext. level to a high voltage source. The BNC socket burned but the DAQ didn't showed any living signs since then. Does someone know what is the problem ?
Thank you
08-12-2014 10:13 AM
You should contact the manufacturer to see if it can be repaired.
This is not a DASYLab software issue.
08-12-2014 10:38 AM
It sounds like you need to buy anouther NI board
08-12-2014 11:48 AM
Why , does it seem I burned the whole board
08-12-2014 12:00 PM
If you cannot see the board with DAQmx, it means that is not working anymore
08-12-2014 12:24 PM
Unless you at least give a shot with restarting the computer and getting the connection back .... (which was successful in deed :manhappy:)
I got it , Thank you anyway
08-12-2014 12:24 PM
Let me reiterate. This is a software forum for DASYLab.
We are not equipped to diagnose your hardware.
Post in a hardware forum, or contact your local support to see if the board can be repaired.
We will not comment further on this discussion.
