07-16-2012 06:28 AM
Hi!
I have a problem while parsing comma delimited data. My oscilloscope transfers 1002 data points via the RS232 interface which are comma delimited. In addition they have a variable length where positive values have 8 bits and negative ones 9. So parsing with a fixed length is hardly possible. I tried a variety of solutions for the measurement format like a\x2C but with no success. I can see the data in the RS232 monitor but how can I work with it in the Dasylab sheet?
Thanks for your help!
07-16-2012 07:44 AM
a\x2c (note the case) should work.
07-16-2012 09:08 AM
07-16-2012 09:23 AM
How does the line terminate?
It looks like it's finding the value in the monitor... as you said. How is the module configured? can you attach the worksheet or images of all of the settings.
07-16-2012 09:42 AM
I tried to make some screenshots of the module. The worksheet itself is not of interest I think. The line ends with \r\n
07-17-2012 04:07 AM
The (output) timebase is set to 15 seconds ( < 1Hz) with bocksize 1002 -- this will take several minutes to fill a single block.
07-17-2012 07:42 AM
For a test, reduce your sample rates to 1/second, with a block size of 1. You can use a Data Window module to recollect them back into a larger block if it works.
Additionally, if this does not work, try changing the INTERFACE settings for the hardware handshake to one of the three bottom choices (in English, they say "Without". These settings hold one or two pins high or low, for some devices that expect that. Try each one in turn, to see if it works. This is a common solution.
07-17-2012 09:35 AM
Another problem is, that the entire data record is terminated by \r\n, but the data values itself are seperated by commas.
The last data value (the one between the last comma and the \r\n) will stay in the buffer while DASYLab waits for the next comma to arrive - forever, or until someone resets the buffer (action-module).
07-18-2012 09:14 AM
I tried all handshaking methods but that didn't help. I also tried a sampling rate of 1 s and a block size of 1, but allthough I have a bunch of data (1002 data points) in the RS232 monitor I only get one single value in a linked list module. This value does only change if I send another data request. I used the data format a\x2c. Any further ideas? I really need help with this.
07-19-2012 02:13 AM
What happens, if you move the data-request from the channel into the "Start-Kommando"-field, and deactivate the "active data-request"-option, too?
My Profile | Privacy |
Legal |
Contact NI
E-Mail this Page
