DASYLab
DataSocket server crashes when trying to connect from a remote computer?
I've encountered a problem trying to access a Datasocket server from another computer on the network. The server computer has the Datasocket server utility running, and the Dasylab program on that computer is successfully writing data to it. However, when I try to select that server in the Datasocket configuration in Dasylab on another computer, it says "No Items" next to the Datasocket server, and the server on the other computer locks up momentarily. I then get a runtime error in Dasylab on the client, and the server begins to run normally again.
Any ideas what may be going on here?
RJ
(6,335 Views)
We are more than happy to assist when the question directly involves National Instruments hardware, otherwise the question is probably best directed to DASYTEC's online technical support.
Glenn
Glenn
(6,326 Views)
Glenn,
Thanks, I have contacted them and they are offering some helpful assistance. I posted here because the Dasylab support website links to this forum for support.
RJ
(6,322 Views)
