The Action module does not affect the data flow rate.
You must interrupt the data flow with a Relay module; you can either use a Trigger module to monitor your event, or the Action module, and use it to Open and Close the Relay.
There are a number of data reduction examples in the Help->Tutorial - it's worth the time to read through them. I generally suggest that at least the first 4 chapters / sections be read. It helps set the environment and fundamentals.
Measurement Computing (MCC) has free technical support. Visit
www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
