02-20-2015 01:10 PM
Hello all,
I am using Dasylab V-13 for control and data acquisition of an automotive end of line component test fixture.
The data write block saves ASCII files and increments files as we test batches of parts. The files are save at 2hz and total file size is approx 32kb.
Obviously, we can review and plot the excel files, but that involves man power.
Since this will be in a plant environment, the request is that a test report is generated per part, with pass/fail at a push of a button (simple?)
We are recording approx 10 parameters. I believe I need to use the ODBC export function, then perform some magic?
Has anyone out there experienced this fun? If so, would you like to share the set-up? Do I need to use Python?
D-lab (Terry)
02-20-2015 01:41 PM
HI Terry,
I think that all you need is the Action module and a layout configured for printing.
You can also use ODBC to export the parameters to a database (or Excel).
If you want, I'll set up an example.
02-20-2015 02:04 PM
What we learn to do with our customers is two options:
