Hi Richard,
In prior testing, I cannot copy a file directly to a FTP://ftp.whatever.com server.
It looks like the crush server offers a drive mapping, like dropbox and one drive have, so that you can save a file to a local folder, and it will replicate out to the server.
(Enterprise licenses only.)
It lets you connect to the CrushFTP server as a normal server drive on your machine. So on OS X this will be a network drive on your desktop, and for Windows this will be a M: drive, or other letter of your choosing. From there on, it acts like a network volume.
I usually recommend ensuring that you have a local copy, and then copy the local copy to the server drive. In the case of a network drive, this eliminates errors associated with network glitches. I have an Action module setup that I can share if you're interested. It can be set up to issue a Windows copy command periodically, even if the file is in use.
Measurement Computing (MCC) has free technical support. Visit
www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
