03-10-2009 06:55 AM
Hello everybody,
I have the following issue. I want to build a trapezoid signal with ranges -2 to 2 Volt, 5Hz and slopes of 4 ms.
I even can't find where to build a trapezoid 😞 Help, please.....
Thanks in regard,
PHeine
03-10-2009 11:19 AM
Does DASYLab S have the Sequence Generator?
If not, you have to create a Generator with a Triangle Waveform, and then use a Scaling Module with Limits to cut off the top.
I don't have DASYLab 6 anymore, so I can't make you an example that you can run.
03-10-2009 11:44 AM
I just tried the following...
Generator with Triangle Wave, 5 Hz, Amplitude of 50, connected to a Scaling module, with the scaling set to1x + 0, and the lower limit of -2, upper limit of 2.
03-12-2009 07:16 AM
Hi there. I think what you are trying to say is I only get a sloped rising edge.
I also want a sloped falling edge.
I have made a drawing and uploaded it into a fotobucket:
<a href="http://www.imagehosting.com/"><img src="" border="0" alt="Image Hosting"></a>
I hope this works. I've never done this.
Thanks anyway for helping me.
Pieter Heine
03-12-2009 07:19 AM
Did you use a Triangle wave? If you cut off the top, you will have both a sloped rising edge and falling edge.
03-12-2009 07:35 AM
03-12-2009 07:50 AM
retry: [URL=http://imgfreehost.com/out.php?t26929_dasylabsignal.JPG][IMG]http://imgfreehost.com/out.php?i26929_dasylabsignal.JPG[/IMG][/URL]
03-12-2009 07:52 AM
beeps! Still no picture! This is the link: http://imgfreehost.com/out.php?i26929_dasylabsignal.JPG
03-12-2009 08:17 AM
Please see the PDF attachment above.
Note... you could have attached the JPG to the post... the attach dialog is at the bottom, below Submit Post.
03-12-2009 08:32 AM
Wow, thanks for the solution guys! It works!
I'll ask somthing later on about a fourier analyse
about this signal.
Again, thanks a lot.
Pieter
