03-04-2009 04:22 PM
03-05-2009 04:30 PM
Hi Cpesko,
Are you using the system clock to read a time signal as in are you planning to use the scan clock? If you are acquiring the data as a waveform you are automatically collecting a timestamp as the waveform consists of 3 components--y, t0 and dt. Please have a look at this post for formatting the timestamp and this one for timestamp in your data. Hope this helps!
Ipshita C.
03-06-2009 10:31 AM
03-07-2009 02:03 PM
You don't understand. If you choose to get a waveform data type, you automatically get a timestamp included in the data. Nothing extra has to be done. How you put that in a file is a different question. The Export Waveforms to Spreadsheet File will do it. Write to Measurement File will have a header with the start time and each row will a dt value (i.e. .001, .002, .etc), or you can create an arry of timestamps from the waveform data type, format it, append it to your data array, and use the Write to Spreadsheet File.
In the future, you might want to post similar questions to the LabVIEW board. Saving to a file is a LabVIEW question and qustions about analog inputs do not belong in the counter forum.
