NI Home
Cart Cart | Help
You are here:
Reply
Sumithra_Nagappan
Accepted Solution
Pulse Measurement
Hai all..
   Im using the counter port in  Usb 6009 to measure the engine rpm  for every 0.1s and save it in lvm file.Aquistion and and logging of data at initial stage say for 10 mins pulse generated is acurate and data are stored for every 0.1s,after 10th minute acquistion speed and and logging speed goes slow and instead of acquiring data for for every 0.1s it measures for 0.12,0.14,0.16, ...0.2,0.3s..and stores it.Due to this i miss n number of pulses and i couldn't provide the proper time resolution.
After an analysis i found that the acquistion depends on both hardware used and the system used.
  My system Configuration is
           Intel core 2 Duo CPU
           2.67GHz, 1GB Ram
can anybody suggest a solution for the above problem,is there any other wya to measure the signals without any loss and delay.?
Trusted Enthusiast
crossrulz
Re: Pulse Measurement
Care to share some code?  It sounds like a memory leak to me.
Kudos always welcome for helpful posts...Kudos always welcome for any post.
Sumithra_Nagappan
ya.Thanks and i have fixed the issue by clearing the buffer once after every acquistion and kept on trial.
sampatti
how we clear the buffer please gide me because iam newer to lab view
Sumithra_Nagappan
Check the attachment.You may get an idea.
