NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
zymale
PXI 6602 measure frequency in real-time
[ Edited ]
I want to use the PXI6602 to measure the  frequency of  a dynamic signal in the  range of 60-300Hz. In my time loop ,I get data  every 10ms. For the 60-100Hz signal,I can get the current frequency in twice.One time use the previous frequency,the other time use current frequency.  But for 100-300Hz signal,every time get at least one data, such as 100Hz only one data and 300 Hz  three data.I found that the   signal within the range of 60-100Hz if the timeout is set to 0.01 seconds, then there will be an error and can not  get any data.Is there any  way that  I can directly read and set the buffer on the board?And  how can I realize  the   program?
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
