09-09-2014 03:33 PM - edited 09-09-2014 03:58 PM
Is it possible to achieve a loop rate of 1us with the Ni7842 RIO board. It has an onboard clock of 40MHz. I have tried the following approaches to achieve a 1us loop rate and generate a single pulse of 1us duration, but wasn't successful.
1st approach: The above flat sequence was originally with 2 frames, I removed the second processing frame to reduce any possible processing delays and changed counter units to usec with a count of 1. This did not work, minimum pulse width I could generate was 1ms.
2nd approach: I changed counter units to ticks with a count of 40. This also was able to generate a min pulse width of 1ms only.
The AO channel is capable of 1MS/s update rate and with an onboard clock of 40Mhz you would think you can achieve 1us. Why is it being so difficult for me? Please help.
PG
09-09-2014 05:18 PM
Show some actual code. If possible, supply a stripped down project that shows this issue. I recommend zipping up this project and any needed VIs and posting the zip file.
