10-09-2015 02:07 PM
I plan to use a NI PXIe-6612 and count up to 8 linear quadrature encoder sensors.
I've determined that quadratures use the Gate, Source and Aux counter I/O. I would like to know if I can se the Out counter I/O as a static digitial input/output with using the same counter for quadrature encoder sensing.
Here is an example.
I connect my quadrature encoder to Counter 1 Gate, Source and Aux connections. Can I use Counter 1 Out connection as a statis digital I/O?
I plan to use P0.0 to P0.7 as digital outputs and need to use the counter OUT connections for digital inputs.
ADam
10-12-2015 02:48 PM
Hi Adam,
Yes, this is doable. The gate, source, aux, and out terminals of the 6612's counters are all PFI lines, which can be configured as static digital I/Os. For more info, refer to page 4-3 of the user manual: http://www.ni.com/pdf/manuals/374008b.pdf
