NI Home
Cart Cart | Help
You are here:
Reply
Member
yipilipi
NI 6602 how to synchronize frequency counter
Hi, i'm working with a NI 6602 board. Actually we have 3 optical encoder connected to ctr0 (pfi38), crt1(PFI34)  and ctr2(PFI30). I need to have synchronous acquisition of frequency. I'm using NI-DAQMX with C . Our goal is to display frequency variation between the 3 entry.
I think using  edge count can be a better way to have synched samples but actually i can't change wiring and cannot connect my source signal to pfi39, pfi35 and pfi31.  I've tried to use  DAQmxSetCICountEdgesTerm(taskHandle,"Dev2/ctr0","Dev2/PFI38") , i have the error  -89120 (signal can't be routed). When i set  DAQmxSetCICountEdgesTerm(taskHandle,"Dev2/ctr0source","Dev2/PFI38") no error but always count 0.
My signal frequency is betwenn 0 and 16000hz.
My code is below
DAQmxErrChk (DAQmxCreateCOPulseChanTime(taskHandleOut,
       "Dev2/ctr4",  // gating pulse generated
       "channel 1",
       DAQmx_Val_Seconds, // units
       DAQmx_Val_Low, // resting state
       0.0,  // initial delay
       0.5,  // pulse train freq 0.,
          0.5));  // pulse shape
 DAQmxErrChk (DAQmxCfgImplicitTiming( taskHandleOut,
      DAQmx_Val_ContSamps,
      0));
DAQmxErrChk (DAQmxCreateCICountEdgesChan( taskHandle,
       "Dev2/ctr0",
       "channel 0",
       DAQmx_Val_Rising,
       0,   // initial count
       DAQmx_Val_CountUp)); // count direction
 DAQmxErrChk (DAQmxCfgSampClkTiming( taskHandle,
      "/Dev2/Ctr4InternalOutput", // sample clock set to pulse gen
      20000000.0,    // max expected rate of sample clock
      DAQmx_Val_Rising,
      10000000));    // buffer size
  DAQmxSetCICountEdgesTerm(taskHandle,"Dev2/ctr0source","Dev2/PFI38");
Active Participant
Remi.D
Re : NI 6602 how to synchronize frequency counter
Hi yipilipi,
To make edge count, you need to put your signal on the counter sources pin. If not you will not get counts!
Rémi D.
National Instruments France
>> Les rencontres techniques de NI - Mesures et acquisition de données : de la théorie à la mise en ...
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
