07-04-2014 04:03 AM
Hello!
I would like to use the NI 6602 Counter in other frequency base than 80MHz, I have read about it, but still couldn't figure out how to do that. I know that I need an other counter to set the frequency then measure with the second counter, which frequency's I have set. Is there any done example for that? or can you help me in this question? Thanks in advance.
Balint
07-09-2014 07:25 AM
Hi gbvbalint,
What exactly are you trying to measure? Why do you want to change the 80MHz?
Do you need a faster source signal or a slower one?
IR
07-10-2014 01:32 AM - edited 07-10-2014 01:33 AM
Hello!
I need a slower signal, I need it for certain kind of measurements.
07-10-2014 01:38 AM
Hi Balint,
There are multiple ways of doing that.
On below links you will find two examples that implements the desired funcitonality.
1. Using another counter you can generate a clock that will be used as a source for your measurement.
https://decibel.ni.com/content/docs/DOC-14643
2. Using only one counter, there is an option of configuring the meausurement for lower frequency, in this case, the driver automatically selects the right clock for that.https://decibel.ni.com/content/docs/DOC-12160
IR
07-11-2014 02:30 AM
Thank you! I will take a look at them.
