09-28-2015 12:04 PM
Can anyone tell me which is the minimum width of a pulse at a digital input that the counter of an USB-6210 module can count?
The specs sheet only talks about the debouncing filter, which has a minimum setting of 125 ns. However, this filter can be disabled. How long does the pulse has to be in order to be detected (counted)?
For example in the NI6602, this time is 5ns without prescaling.
Any help will be appreciated
Miguel
09-29-2015 12:44 PM - edited 09-29-2015 12:46 PM
Hi richilarro.,
You can read the explanation related in http://digital.ni.com/public.nsf/allkb/9ECE7DBE7DF338BD86256F8600734A41 , I think this information may help you to solve the issue.
Greetings
09-30-2015 06:52 AM
Thanks LeninMartin for the reply;
but I still don't know if a clean 10 ns pulse will be counted by this module in the counting mode, or if it will be skipped. I understand the debouncing filter options, and I do not want to use any filter, so I can enter with a pulse as short as I can. How short this pulse can be?
richi
09-30-2015 12:42 PM
Hello richilarro.,
I had read the information related with this subject and the minimum pulse width for your device is the 125 ns, if you disable the filter.
Regards.,
09-30-2015 12:44 PM
OK, great, thank you!
10-01-2015 11:29 AM
Greetings
