I am trying to create a temperature process controller. I have 3 RS232-enabled OMEGA mass flow controllers, 12 thermocouples, 6 heaters (that will be connected in sets of two), and 3 PWM-enabled fan banks.
My thinking is that I would connect the heaters in parallel to a phase-angle-fired SSR (http://www.chromalox.com/catalog/resources/PDS-PK308-SSR.pdf). That way, I could use a 0-20 mA output signal from the cRIO to control the power appplied to the heaters. I would use PID, and scale the output of the PID to a 0-20 mA signal to control the process temperature. I also want cascade control - I want to have 2 additional thermocouples that are connected to the PID loop acting as limit sensors. If the temperature limit is exceeded in either thermocouple, the PID loop is "turned off" until reset by a user. I would want three of these configurations (2 heaters, 3 thermocouples, 1 SSR - x3, so 6 heaters, 9 thermocouples, 3 SSRs).
Rather than control the PWM fans with a PWM output directly from the cRIO (which I heard can be painful) I found a PWM controller that is controlled by a 0-5VDC signal. I wanted to use a thermocouple as a process value, and the 0-5VDC signal would scale to control the fans to achieve the desired temperature. I would want three of these configurations (1 fan bank, 1 thermocouple - x3, so 3 fan banks, 3 thermocouples).
So now, my REAL question - Would one cRIO chassis be able to control these 6 PID loops AND my OMEGA mass flow controllers? I'm just unsure of the processing power that is required of PID/limit control.
I appreciate any help I get - If need any more specifics, please let me know!
Thanks!
