NI Home
Cart Cart | Help
You are here:
Reply
Member
walletok
Accepted Solution
How can I use analog signal trigger my PXI-6115 counter to generate frequency pulse
I'm working on  a PXI-6115 DAQ card and want using analog signal to trigger it's counter generate frequency pulse. The user manual says the analog trigger is supported, but  I can't use a analog signal to trigger it start work, in the test I use counter 0 to generate pulse and use PFI 0 as analog trigger signal input port, can anyone tell me what the matter is? My test VI. & error message is showing in attachment .
Best regards
Active Participant
snowpunter
Re: How can I use analog signal trigger my PXI-6115 counter to generate frequency pulse
If you read the error you can see that digital triggers are the only available trigger when using Counter Output.
You can get around this by setting up a dummy Analog Input task that will fire an internal digital trigger when it sees the appropriate analog trigger.
See this thread for more details:
http://forums.ni.com/t5/LabVIEW/DAQmx-Start-Trigger-Analog-Edge-vi-Keeps-Returning-Error-200077/m-p/...
CTA, CLD, MTFBWY
Member
walletok
Hi, snowpunter
Thanks for your response.
AnologComparisonEvent is a evil event, Even if 6115 analoge channels without retrigger function, it can offer a internal trigger pulse  everytime  the analoge trigger signal fit pre-set trigger state. Now I use AnalogComparisonEvent as CO clock source and CO task is working properly .
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
